Dr. BUGMAN wrote:Reading that again, it occurred to me that the Dark Ring could be the Chaos Ring Eggman witnessed being minted, only this one was corrupted by him somehow. If there are seven Emeralds, then it's likely there are seven CRs, too.
This relies or on whether the manual is referring to a single or multiple Chaos+Dark Ring(s). Two of the three translations (including Windii's) refer to "the Dark Ring," suggesting there's only one and leading to the assumption that it's referring to the big ring we destroy at the end. But we
know there are multiple Dark Rings because enemies drop them and all 5 bosses are powered by them. If there are multiple Dark Rings and Eggman only saw one Chaos Ring get created, then the big ring could potentially be a Chaos Ring (even though it doesn't look like one at all). But if there were multiple Chaos Rings formed then it wouldn't make sense for Eggman to have only grabbed one, and if "the Dark Ring" referred to in the two translations is the big ring then it's not a naturally created Chaos Ring because all 3 translations call the Dark Ring(s) artificial/synthetic, right after describing that Eggman had succeeded in crystallizing Pillar energy (i.e., they're artificial Chaos Rings).
Dr. BUGMAN wrote:Anyways, would to stand to reason that Giant Rings functioning as goals from SA2-onwards might be because they're made by Eggman to zip around faster than otherwise possible? Maybe that's also why CEs are frequently seen outside SSes; they're no longer secure locations.
Goal rings have appeared in levels Eggman never had a presence in, but I really like the concept! Flickies' Island
does come after Chaotix and shortly before SA1, so it makes sense both in terms of Eggman's technology logically progressing after studying the Special Ring and in terms of when we start seeing big rings used as goals. It's the last game where the emeralds are in the Special Stage other than Heroes, excluding handheld. Also, Sonic R comes shortly after Flickies' Island and features that seemingly infinite ring dispenser. Could be another step on the same technology ladder!
Realistically, the Dimension Ring Generator should have been a
huge game changer for Eggman. Fiction rarely captures how much of a force multiplier a teleporter is both militarily and economically. It only opens portals to the Flickie dimension (probably the Special Stage), and he probably can't build a base in there anymore like he intended, but he could still use it as a pass-through to effectively teleport anywhere that he can open a portal (like using Nether portals as a shortcut in Minecraft). The only way this wouldn't have made him immensely more powerful is if it only worked on Flickies' Island or if the Flickies found a way to lock him out.
chriscaffee wrote:But if you look at the landmass under the shrine in the Present, it's clear that miles of real estate underneath the shrine were pulled up into the sky but...again, the temple and most of the mystic ruins were left behind?
Ok, you've got me there. The NPC dialogue in SA1 actually says the altar is "in front of the gate," so the transition from the temple to the altar isn't abridging any significant distance; it's literally a matter of yards. So if the Master Emerald rose the island while it was on the shrine altar then it put itself at the very edge of the island, which would be weird. Maybe it was moved to Hidden Palace before the island ascended. The shrine IS at the edge of the island in SA1, which is where it would be if it was taken up with the rest of it, but I do agree that the way the shrine is floating on its own in SA1 doesn't line up with that, and the mountains are in the wrong place, etc. Either the gods were being weird again or it got brought up (probably by the gods) from Neutrogic.
But I
don't think that shrine is where the Special Ring takes him because the Pillar isn't there and he needs to somehow get a source of Pillar energy to mass produce Dark Rings. Saying it takes him to the Special Stage makes sense in terms of his witnessing the creation of the Chaos Rings and potentially giving him access to Pillar energy, but if the Special Ring is just like every other big ring in every game then why is this a significant discovery? Surely he'd seen them before! The manual says "he discovered a Super Ring identical to the one on the floating island. It was an ancient Special Ring that was used by the legendary civilization before it was lost." The Hyper Rings are unique to Angel Island (and are visually distinct, at least in gameplay), while big rings are everywhere, so that fits the sentence better. He would also not expect to find the Master Emerald in the Special Stage, which is where he would expect a big ring to take him, because it's never been in there as far as we know.
chriscaffee wrote:Is it confirmed that the Ring that Eggman travels in the end was a Dark Ring? I thought that was the original Super Ring that he discovered? I assumed the "Square" around it was his scanners or whatever studying the ring.
You know what? That's a good point. Here, let's make this convenient.
I completely forgot that the regular bosses are also powered by Dark Rings. They're bigger than the ones powering badniks, but smaller than the ring in the end cutscenes. Inside the cube it looks exactly like a portal ring, but then when he deactivates it
normal rings fly out, then it looks...completely unique. It no longer rotates, and it's darker and thinner than a portal ring. It might be the same tone as the big Dark Rings, but it's hard to say. Maybe it's meant to be a combination of the two, as if he somehow corrupted the original Special Ring similar to what Dr. BUGMAN suggested (Dark Rings are just crystallized Pillar energy, but they don't look like the naturally occurring Chaos Rings, so maybe whatever causes that corruption affected the Special Ring).
Here's something we've been overlooking though: the ending only makes sense if Eggman can no longer produce Dark Rings. Destroying the cutscene ring is the difference between a good and bad ending, and given that he never makes Dark Rings in future games it follows that this cutscene ring is what was allowing him to make them. If he can't reproduce it, then it must be something he found, i.e. the Special Ring he finds in the manual. Dark Rings are just crystallized Pillar energy, so that means that either 1) the Special Ring was a critical part of the crystallization process, or 2) the Special Ring is what gave him access to Pillar energy. Coming back to my earlier point, big rings can be found anywhere, ergo the Special Ring HAS to be a Hyper Ring, otherwise he could set up shop again basically anywhere and make more Dark Rings. Hyper Rings are only on Angel Island as far as we know, and setting up a base there would not be practical with Knuckles around, so by destroying his captive Hyper Ring we prevent him from creating any more Dark Rings. In Flickies' Island he figures out how to make Special Stage portals himself, but he probably needs to open them from the outside or some such restriction, and if he could get close enough to the Master Emerald to set one up then he could just steal it.
But there's a better version of this idea that fits the cutscene more closely. Here's my new theory. The wire-frame cube with a portal ring inside is the Special Ring he found, a typical Hyper Ring going to Hidden Palace. The cube represents his machine harvesting Pillar energy through it. He then either closed the portal intentionally out of arrogance (because he didn't need it anymore and didn't want his enemies to escape through it) or sucked so much through it at once that it destabilized, collapsing into 50 normal rings ala S3&K. What was left behind was just a really big Dark Ring that he was in the middle of creating: his master plan all along. In the good ending we destroy this Super Dark Ring, thus de-powering Metal Sonic Kai, but the real reason we've won the day is because Eggman no longer has access to a Hyper Ring. Whatever caused it to close, it's gone. And the only other place to get one is guarded by a very aggressive echidna.
It's possible that the intent of the wire-frame cube was to show a portal generating machine, which fits with Eggman believing that studying the Special Ring (learning how to create them) would allow him to steal the Master Emerald, and with the development of the ring tether, and makes him closing it seem less reckless, but then the ending wouldn't make sense because he would just make a new portal generating machine the next day (unless he
found a portal generating machine and the manual just didn't mention it). I wouldn't put it past Sonic Team, though.
Earlier I asked myself how Pillar Energy rising into the Special Ring could create Chaos Rings in the Special Stage if the Special Ring is just a bridge from Neutrogic to Hidden Palace. Maybe the way that Hyper Rings work is to briefly cross through the Special Stage, similar to how Scorpion from Mortal Kombat or Nightcrawler from X-Men teleport by briefly warping in and out of Hell, and the Pillar energy got stuck in there because of the way it reacts with the physics of that Zone (which could also explain why it only crystallizes there and not in our world).
I'll rant about the Pillar another day.
Fun fact: Amy's in the sound test.
